Ground Unite Vs Estimate depth
Options
JiangyuLi
JiangyuLi Posts: 2
edited September 2019 in Oasis montaj
Hi Guys,
I have a question while applying Montaj to do some upward continuation and would like to ask you about it.
Do you know how to transfer the ground unite to estimate depth.
In the upward continuation, I chose the ground unite around 0.1, but what is 0.1 ground unite means interms of continuation depth, how could I konw the depth that I continuated??
This have puzzle me for a while, any help will be greatly appreciated!
Cheers,
Jiang
  • it should be units of the dataset- I'm guessing you're using geodetic (Degrees) rather than UTM or equivalent (in metres)- so you may want to reproject
  • Hi Andrew and Darren, thanks so much for your reply, now I got it!
    Cheers,
    Jiang
