Compute voxel of distances to drill holes
NickWilliams
in Oasis montaj
Hi @NickWilliams, I'm trying to think this through and find a relatively simple workaround for you, but nothing has really worked out yet. What are you planning to use this for? A VOXI constraint?
Here's one idea I haven't worked all the bugs out of yet but I think is doable:
Use voxel direct gridding and blanking distance to create a series of voxels that have increasing blanking distance as you get farther from the drillhole. The first voxel would be directly over the drillhole traces. The 2nd would be 1 cell away, the 3rd voxel would be 2 cells away, etc.
Then use voxel math to nestle them one inside the other. It would be sort of chunky and maybe not as smooth a transition of distance that you were looking for. Is this what you were looking for?
Does that explanation make sense? Should I continue down this path? What sort of distances are you interested in? How far from the drillhole are you interested in seeing for example? And are you working in an area with a big cluster of drillholes, and what's the average distance between them?
1 -
Thanks all. I will typically be using many curved drill holes. I'll try these out. The main purpose at this stage is for visualization (ie, show me anomalies >100 m from a drill hole), but if I can be done easily there are also some interesting options for applying different sorts of constraints to VOXI models.0
@ElizabethBaranyi I tested this approach and it works well. A few notes though:
- The parameter 'd' in the formula you posted above is measured in "cells". It must be multiplied by the cell size to get the actual distance.
- The calculation only works to a distance of 10 cells from any drill hole.
- It looks like the calculation only takes into account the lateral distance to a drill hole on any layer of the mesh instead of using true 3D distances. It produces cylinders with flat tops and flat bottoms instead of producing a hemisphere at the end of each drill hole.
It's a very good start and will serve most purposes.
Thanks for your great idea!
Nick0 - The parameter 'd' in the formula you posted above is measured in "cells". It must be multiplied by the cell size to get the actual distance.
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
