Uploading polygons to GPS
MwapeSomanje
in Oasis montaj
Dear All
Does anyone know the easiest program/software I can use to upload polygons like an exploration license from a PC to a handheld GPS easily. Am able to load waypoints like a planned soil sampling grid but am stuck with uploading polygons or rather tracks.
Please help
Mwape
Please help
Mwape
Looks like nobody knows how to0
Hi @MwapeSomanje, I'm not sure if this helps but I know that some handheld GPS' (Garmins for example) support GPX and KMZ files. You could try exporting your polygons in Oasis montaj to KMZ directly and see if that takes.
1. In your map turn off all layers except the polygon you want to upload to GPS.
2. Map > Export > Under Output Format select Keyhole Markup Language (*.kmz).
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
