fly lines
geosoftdehispa
How I can eliminate the fly lines noise?
Hi @geosoftdehispa, if your gridded data looks something like the following image, then you need to do some line levelling.
There is a Learning Path called "Geophysics Levelling" with all the steps and corrections available here:
https://my.geosoft.com/elearning/step/825
If that's not the type of line noise you mean, can you share an image or elaborate on the problem you are seeing?
Community Manager0 -
The image it's normal the noise come when I tried to release some filters.0
