fly lines
Options
geosoftdehispa
geosoftdehispa Posts: 34 Calcite Rank Badge
edited December 2018 in Oasis montaj
How I can eliminate the fly lines noise?
  • BeckyBodger
    BeckyBodger Posts: 337 mod
    Options
    Hi @geosoftdehispa, if your gridded data looks something like the following image, then you need to do some line levelling.
    There is a Learning Path called "Geophysics Levelling" with all the steps and corrections available here:
    https://my.geosoft.com/elearning/step/825
    If that's not the type of line noise you mean, can you share an image or elaborate on the problem you are seeing?
    Community Manager
  • geosoftdehispa
    Options
    The image it's normal the noise come when I tried to release some filters.
