python_desktop_setup.gx not properly working
DietmarKopp
DietmarKopp Posts: 10 Fluorite Rank Badge
I am on Anaconda3 Python 3.61 Oasis Montaj 9.3.1
I downloaded the python_desktop_setup.gx
However, when I run it, I get the prompt to enable that menu but the menu is not available in the menu manager.
I get no error or anything.
Any help?
  • I tried that, however, it doesn't show up.
    I tried confirming the error on other mashines, same licence, no error, works just fine.
    So I guess I kinda broke something when I installed the "Potent" plugin way back when.
    I was trying to do this for making a tutorial(company) anyway, Python works just fine from when I installed it in 9.0
    So I guess issue kinda solved but I think in your Patchnotes a big and visible sign to update the geosoft python module after updating to 9.5 should be included, took me hours to see that it was necessary :)
  • If you have another menu (file) of the same name placed in the OM\omn directory, it will block the version in OM\user\omn from working.
  • Hi @SteveBedell, Did the GX run without error? If so, when you browse to c:\Program Files\Geosoft\Desktop Applications 9\user\omn, do you find the Python.omn file there?
