Can I export only active groups or folders to a new map?
ToddBallantyne
in Oasis montaj
I have a large regional compilation map and would like to save a few specific groups or folders to a new map in order to send to the client. I know that I could do this via duplicate map, but I would need to delete all the other groups and folders and leave only the new work. I can think several of work-arounds, but all take extra work and finagling.
If "map/duplicate map" had another option that allowed for only "active or selected objects" that would solve my problem… It would be similar to options for exporting a GDB subset.
If not available please add as feature request
Hi @ToddBallantyne, I will add this as a request. If it helps, you can drag and drop multiple layers at the same time from one map to another, however it does not preserve the folder structure.0
Categories
- All Categories
- Community
- 16 Latest Releases
- 15 Member Spotlight
- 38 Learning
- Products
- Geology
- 535 Leapfrog
- 1 Volsung
- 25 Visible Geology
- 14 MX Deposit
- 13 Central
- 9 Imago
- Geotechnical
- 136 GeoStudio
- Geophysics
- 319 Oasis montaj
- 1 Workbench
- SPIA
- 9 Res2DInv & Res3DInv
- 3 Evo
- 25 GX Developer
