Negative Euler Deconvolution solutions
QuentinMarcANABAFOTZ
in Oasis montaj
Hello everyone
I am a Geosoft beginner
Please I wish to know what is the meaning of negative depth solutions in Euler. Are they to dismiss from the solution list ???
Thanks in advance
Thanks in advance
DarrenAndrews thank you for your wonderful answer
let's assume we set the survey elevation to 0 to calculate euler solutions, will the solutions from Euler represent depths below ground surface? if not how to derive depth from surface value?
0 -
@DarrenAndrews thank you for your reply. This is the answer I needed0
Hi @ClaudiaPeredo, if you did not specify a survey elevation, it will use "flying height" which by default is set to zero.
https://my.geosoft.com/supportcentre#/help/oasismontaj-extensions-e3decon_gx.htm0
