Grid stitching
CalistusRamotoroko
in Oasis montaj
Please help stitch two grids not overlapping. I tried Gridknit within Geosoft's but failed. Apparently it can only work if the two grids overlap
Hi @CalistusRamotoroko have you tried Grid Mosaic? This should work when your grids have no overlap.
- From the Grid and Image menu click Utilities and select Grid mosaic from grid files.
- Click the browse button and select your two grids at the same time.
- Enter a new name for the combined grid and click ok.
0 - From the Grid and Image menu click Utilities and select Grid mosaic from grid files.
Hi @BeckyBodger. Thank you very much. Grid Mosaic actually worked for me and also went through a few articles and discovered Boolean operations under utilities within Geosoft works.
2
