Grid stitching
Please help stitch two grids not overlapping. I tried Gridknit within Geosoft's but failed. Apparently it can only work if the two grids overlap
  • Hi @CalistusRamotoroko have you tried Grid Mosaic? This should work when your grids have no overlap.
    1. From the Grid and Image menu click Utilities and select Grid mosaic from grid files.
    2. Click the browse button and select your two grids at the same time.
    3. Enter a new name for the combined grid and click ok.
  • Hi @BeckyBodger. Thank you very much. Grid Mosaic actually worked for me and also went through a few articles and discovered Boolean operations under utilities within Geosoft works.
