outcrop lithology grid
NelsonCamposAlvarez
in Oasis montaj
I have a grid of surface (i.e., outcrop) rock samples that I have classified by lithology types (e.g., granite, granodiorite, etc)
How can I plot a map showing the distribution on surface of the diffetent types of lithologies, differentiated by color and symbol?
Is it possible to create a grid with the lithology types, in a similar way than when a grid of a numeric value is created?
Hello @NelsonCamposAlvarez. You can certainly create a grid of lithology types. In order to do so, you would need to assign a numerical "index" value for each type of lithology. If your rock sample data is already in a Geosoft database, then simply create a new channel in that database that contains a number that relates to each individual lithology, for example:
Lithology ; Index Value
Granite ; 1
Basalt ; 2
Granite ; 1
Sandstone ; 3
Gneiss ; 4
Basalt ; 2
Once you have created the index channel, you can then grid that particular channel using any of the Geosoft gridding algorithms.
I hope this helps.
Best regards,Darren Andrews
Technical Team Manager0
