Learning
Brand new to a Seequent product? Or looking to upskill or refresh your skills? Explore our dynamic, free online learning paths, designed for you to learn at your own pace. By completing a learning path, not only will you advance to the next level, but you'll also earn badges and points in our community.
Our selection of learning paths is always growing, so keep checking back for new additions. Here's what's available for you right now:
Leapfrog
Difficulty: Basic
Length: 14 Hours
Description: New to Leapfrog Geo or looking for a little refresher? Enrol in this course to accelerate your Leapfrog learning curve. Start building better models more efficiently, and learn helpful tips and tricks along the way. In this course, you will learn the fundamental concepts and tools necessary to get you going in Leapfrog, including data import and visualisation, geological and numeric modelling workflows, dynamic model updating, and output generation.
Review: 5 stars (286 Reviews)
Difficulty: Basic
Length: 14 Hours
Description: This course assumes a basic working knowledge of Leapfrog Geo, as well as the concepts of geostatistics and estimation techniques. We will begin with a Leapfrog Geo project containing a topography, some drilling information and a geological model and we will go through the process needed to make a domained estimation and estimate and report on a resource.
Review: 5 stars (50 Reviews)
Building a Model From a Map in Leapfrog
Difficulty: Basic
Length: 80 Mins
Description: Are you starting a new project in a new area? Don't have any drilling data? Create a geological model from publicly available map data! This course is designed for beginner users of Leapfrog.
Review: 5 stars (160 Reviews)
Difficulty: Basic
Length: 3hrs
Description: This course is designed for Leapfrog users who would like to incorporate their Geophysics data into their modelling. This short course has three parts: In parts 1& 2 we will show you how to import 2D and 3D SEG-Y data and visualise it in Leapfrog, as well as using this information to edit and create surfaces in your geological model. In part 3 we will import a magnetotelluric grid and use this to create a numeric model using IDW interpolation.
Review: 5 stars (39 Reviews)
This short module discusses the elements and best use of points and polylines found in the polyline tool in Leapfrog. This course is presented in Leapfrog Geo, but the same tools and workflows covered are also applicable in Leapfrog Geothermal, Edge and Works.
Review: 5 stars (21 Reviews)
Leapfrog Advanced Surface Editing
Difficulty: Advanced
Length: 90 mins
Description: In this course, we will explore the surface controls, such as resolution, snapping and intrusion value clipping, and the different editing options, such as incorporating additional data types into the surface, applying global and structural trends and editing with polylines and points, to manipulate geological model surfaces.
Review: 5 stars (28 Reviews)
Seequent Central
Difficulty: Basic
Length: 5 hrs
Description: Are you or your team new to Seequent Central, undertaking a trial or just looking for a refresher? This course will introduce you to the key concepts you will need to get your team setup with new collaborative workflows using Central. Join us to learn how you can start building better models using the whole team's expertise for a more efficient and effective approach to team collaboration.
Review: 5 stars (36 Reviews)
Oasis montaj
Difficulty: Intermediate
Length: 12 hrs
Description: New to Oasis montaj or looking for a refresher? This learning path teaches you how to best use the tools and workflows that Oasis montaj offers, in order to make the most of your geoscience data. This learning path covers creating projects, importing data, and becoming familiar with the Geosoft database. Workflows for gridding data and creating maps are also covered. More advanced topics are also covered in the learning path, including working with array data, applying filters, creating sections, working in 3D, scripting and windowing your data. To make the most of this learning path, please ensure you have a stable internet connection, and a secondary screen is highly recommended.
Working with Oasis montaj Gravity and Terrain Correction
Description: Learn how to import, process and correct your gravity data using the Oasis montaj Gravity and Terrain Correction extension! This course should take you approximately two hours to complete.
Review: 5 stars (16 Reviews)
Working with Oasis montaj Airborne Quality Control
Length: 3hrs
The Oasis montaj Airborne Quality Control extension provides a comprehensive tool set to help you plan airborne geophysical surveys and ensure that surveys meet their specifications. The extension enables the user to plan flight paths, general statistical reports and run quality control tests.
This course will teach you how to use the various tools within this extension, using hypothetical airborne survey specifications and a sample dataset.
Review: 5 stars (6 Reviews)
Working with Oasis montaj UAV Merge Sorties
Length: 3hrs
The Oasis montaj UAV Merge Sorties extension provides a comprehensive tool set to help you plan Unmanned Aerial Vehicle (UAV) magnetic surveys and process the resultant data. The extension enables the user to plan surveys and import, correct, level and merge data from individual, adjoining UAV sorties into a single coherent dataset.
This course will teach you how to use the various tools within this extension, to plan and process a UAV survey, using a sample dataset.
Review: 4 stars (4 Reviews)
Target
Target Fundamentals
Difficulty: Basic
Length: 8hrs
Review: 5 stars (9 Reviews)
Target for ArcGIS Pro Fundamentals
Difficulty: Basic
Length: 5hrs
New to Target for ArcGIS Pro or looking for a refresher? Learn the fundamental tools and workflows for working with Target for ArcGIS Pro.
Participants will learn how to work with geoscience data within Target for ArcGIS Pro by working through this data driven course. The course will help you become familiar with both the ArcGIS Pro environment and the geoscience data specific tools that Target offers.
To make the most of this course, please ensure you have a stable internet connection, and a secondary monitor/screen is highly recommended.
