When exporting sections, how do I export borehole lines/paths with the model (dwg)?
RobertMillar
My goal is to export the cross sections to dwg for engineers to bring into the CAD drawings. When I export the sections, only the block models are created. How can I retain the borehole paths with the model in dwg? Attached are figures depicting the dwg and section.
Thanks!
Although it may not be a real solution for the issue you are facing, if you export only the well traces of the profile as a tiff file, they will plot in the correct coordinates. The only thing is that the traces are not editable like a .dwg file would be.
