Accumulated length
Hey there, Anyone knows how can I create an accumulate length or a total length for different units for drillholes, using Leapfrog Geo or Edge?
Thanks so much for this tip Kathryn! It works well👍️
For intervals imported into Leapfrog, the interval length is automatically calculated. You can create a variable for this in the calculations for your drillhole. Right click drilling table > Calculations. Create a New Numeric calculation where the result is the interval length metadata.
If you are looking for the length of a unit, you can combine the above, with a composite to determine length.
Leapfrog has an economic composite that will calculate the length above a certain grade -
Or a Numeric Composite -
if you use the Numeric composite, with a large composite length (greater than the longest interval), and composite to a subset of codes, and then calculate the length of the unit.
- 288 Community
