Target for ArcGIS Pro: geosoftarcpy module not found error, no tools work.
RobertCharnock
in Oasis montaj
No tools work at all due to the same error: "geosoftarcpy" module not found.
Is "_geosoftarcpy.cp39-win_amd64.py" the correct file name? That is the only script with a similar name as geosoftarcpy in the Target for ArcGIS Pro folder.
Specifically, it is located here: C:\Program Files\Geosoft\Target for ArcGIS Pro\toolbox\geosoftarcpy.
However, "_geosoftarcpy.cp39-win_amd64.py" does not open in IDLE.
I am using ArcPro 3.3.0 and Target for ArcGIS Pro 2024.1
Adding the toolbox does not work, I get the same error and the toolbox link is broken.
Hey It looks like ArcPro 3.3 is not currently supported. You can switch to ArcPro 3.2 with the latest release
- 288 Community
