Python Error: module 'numpy' has no attribute 'float'
Hi All,
I'm trying to get data from a database using GX Developer Python API. Whatever I do, I keep getting the following error
NumPy downgrading to 1.20 doesn't help. Any ideas about what could be wrong?
any luck with this? I'm running successfully with an older environment where the gxpy.gdb works fine (incidentally this env has numpy 1.24.2, pandas 2.0.0, Geosoft 2022.2.0 - although when I recreate a new env with these same packages I get same error as you!). For now I can only run in my original env but not in any new env I create.
Yep. I've commented out all references to np.float and np.int (two in the gx_dtype function and two in the gx_dummy function) in the utility.py file (.\site-packages\geosoft\gxpy\utility.py). That was the only solution that worked for me.
ok great. that seems to have worked :)
- 5 Community
- 15 Member Spotlight
- 39 Learning
- 2 Products
- 1 Geology
- 535 Leapfrog
- Geotechnical
- Geophysics
- 319 Oasis montaj
- 9 Res2DInv & Res3DInv
- 26 GX Developer
