Sequent Connector Certificate
Hi All,
I'm running Leapfrog or the first time on this machine and this is the error message i get when i try to access the connector. Can anyone help?
Hi you will need to reinstall your Seequent connector for this. The instructions to do this are below:
Close your Leapfrog application.
Sign out and exit Seequent Connector from the system tray located in the lower right of the window
Go to Control Panel> Programs and features, right-click on Seequent Connector and select uninstall.
Delete the following folders:
C:\Users%USERNAME%\AppData\Local\Geosoft\Geosoft Connect Settings
C:\Users%USERNAME%\AppData\Local\Geosoft_Inc\Geosoft Connect
Download and install the new version of Seequent Connector from the following link: https://downloads.seequent.com/Geosoft/SeequentConnector.zip
Launch your Seequent application.
Sign In with your Seequent ID.
If the above steps do not work, try to restart your computer
Let us know how you get on.0 -
Hello @MatthewMurphy
I have tried the above solution and am still unable to sign in.
