error: "invalid point index in tri"
When importing a mesh I received the following error: import failed: The VULCAN file Geo_401_DG3.00t could not be imported as a mesh: invalid point index in tri
I've imported other meshes for the same project and they were all fine. I've tried removing intersecting volumes and removing verticle edges - but the error remains.
any ideas on what causes this and the best way to solve it?
  • AmeliaOrmeno
    AmeliaOrmeno Employee Posts: 8 Calcite Rank Badge
    Hi Ana,
    If all the previously files were exported at the same time, you should take a look the file. It is probably that somehow It get corrupted. So, I'd recommend to re-export the mesh. Hope this can help.
