adding prefixes or other text onto cross section layouts
Does anyone have a workflow for adding text "prefixes" to borehole data displaying on a cross section layout? I've been looking into calculation fields, but without much luck.
For context, I want my cross section N values to say "N=" to the left of the data. For instance in the image below I'd like it to say N=11.0 and N=9.0 on the left, then Su=1715 psf on the right. Any ideas?
There are two approaches I can think of, the easiest; export the column to excel and add the prefix in excel then reimport as a category column into Leapfrog, use this column on your section.
Alternatively make a table with a column of N= at the same depth as your SPT values then import that column as a category column, you could then use the offset setting when you add the points to the section to make it line up.
Richard,
Thanks very much! those are both viable options. I appreciate it!
