Create Attributes in Imago Portal
MarissaDoherty
MarissaDoherty Posts: 29 admin
edited October 2023 in Social Groups
In many instances you will want to upload attribute data to Imago. Attributes are fields of type String, Number, Notes, etc. that allow you to incorporate structured data into Imago. This may be useful for example when you are creating log view.
You must have the permission of the subscription owner in order to manage and create attributes. If you do not see the relevant screen shown below, you do not have the necessary permission.
Once you define the Attribute Definition which is the grouping category for the Attributes.  An Attribute is then define with its data type. For the example below the Au attribute is defined as a number.
And can also have a legend:
 An Attribute Definition must be assigned to a Imagery Type so it can be used. The Imagery Type is the interval that will used to assign the attribute. If the attribute you are importing have different interval (From-To) you must create an Imagery Type for each one.
The Imagery Type must then be assigned to the Workspace --> Dataset for it to become available for use.
