Export Templates in MX Deposit
Export templates provide complete control over what data gets exported from MX Deposit, and how it appears in the export files. You can select the header/fields/tables/columns that you want to include in the export, you can set export labels for files and column header, and you can set filters and rankings to control what data is exported.
First, you must configure your export template and configure all the various export options. Once the template configuration is complete, it then becomes an option in the export icon on the main drill hole/point landing screen. You can set an export template to be private or shared, depending on whether only you should see the option or if all users can see the option.
Exporting using an export template works much the same as the default Export function, except that you can customize the output.
Every user that has access to the export module can create export templates. Export templates that are "private" are only visible to the original creator of the template. Export templates that are "shared" are visible to all users that have access to the project. Only the original creator of the export template can edit it, with the exception of users that have the "admin" role (who can edit any template).
Learn more.
