Exporting Data from MX Deposit
MarissaDoherty
MarissaDoherty Posts: 29 admin
edited October 2023 in Social Groups
You can quickly export your data from MX Deposit to CSV files using the built-in export function.
The default behaviour of the export is that every table is exported as a CSV file and the headers in the CSV file match exactly as they appear in MX Deposit. If you want to customize the export, you can make use of the Export Templates feature.
If you are exporting data for multiple projects, the data will be exported for each activity. That is - you will get a set of CSV files for each activity.
 How it Works
The steps to export your data are:
  • Select the list of holes or points to be exported;
  • Click the Export icon;
  • Select your export options;
  • Click Export.
The data for the selected list of drill holes or points will be compiled into CSV files and a compressed (.ZIP) file will be downloaded to your computer.
Find out more.
