How do I select points I don't want to model?
CarolineCozer
Posts: 2 New Member
Hi Caroline,
You can use the tool category selection on points. To do this right click on the points object and choose category selection. This page in help explains the tool: Categorising Points (seequent.com).
This will allow you to make a new column on your points table. If you then use filters based on that column to control what data you are using to build surfaces or visualizing in the scene. You could even then apply the filter in the points table to bulk ignore rows.
Richard
