How do you display the 'exponent' on cross sections
DamianWilliams
attempting to display (k) / permeability downhole on cross section but not seeing an option in labels that allows for the display of an exponent
and decimals places limited to 4. Have already tried reducing and create discrete interval (colourmap)
Hi @DamianWilliams.
Unfortunately, there is a limit to the number of decimals shown in cross section view. I'm seeing 4 Decimals max when displaying numeric data on interval data, and 8 Decimals max when showing Point Data, shown below.
A workflow that might suit your needs in the meantime would be completing some Unit conversions of your data using Calculations. For instance, changing your K from ft/day to meters/day.
You can read more on Unit Conversions using Calculations in Leapfrog here: https://help.seequent.com/Works/2022.1/en-GB/Content/calcsfilters/catalogue.htm#unit-conversion.
One other trick to be aware of is using Rounding Functions within Calculations which can sometimes help in situations like this. https://my.seequent.com/support/search/knowledgebase/ka04S000000gotwQAA
Sean1
Should have mentioned this is when using LF Works0
Sean, thanks much for the response! We used conversion method as suggested.1
