Block Model - filter and display
Options
MarkusStaubmann
Is it possible to display a block model with a value filter applied, and have the blocks coloured by a different evaluation that is included in the model?
For example, display only the >1g/t Au blocks but the colour range is based on Cu
Yes this is possible. You need to create a Filter on the 'Calculations and Filters' tab for the block model, accessible by right clicking on the block model. You can then apply this filter and colour by another variable.
Hi Ryan, thanks for the reply.
When I right click on the block model in the project tree - I only have the 'evaluations' option to open the Grid and Evaluations tabs, there is no 'Calculations and Filters' tab.
Just for clarity - this particular model is based on a project that only has point data (no 'drill hole data'), so the various numeric models that are included in the block model are from a point data source - not that this should matter.0
