Issue calling new CGX_Net from standalone program
I recently upgraded Montaj, and a C# dotnet standalone program has stopped working, in the call to new CGX_NET in the final line of the following code snippet:
//IntPtr hWnd = (IntPtr)Windows.
//IntPtr handle = Process.GetCurrentProcess().MainWindowHandle;
//NativeWindow nativeWindow = new NativeWindow();
//nativeWindow.AssignHandle(handle);
// var hwnd = new WindowInteropHelper(handle).Handle;
// Pro
//string dllPath = "geosoft.desktop.gxnet.dll";
// Assembly desktoGxNet = Assembly.LoadFrom(dllPath);
//dllPath = "geoengine.core.gxnet.dll";
//Assembly coreGxNet = Assembly.LoadFrom(dllPath);
// dllPath = "GeoEngine.Core.Managed.dll";
// // Assembly coreManaged = Assembly.LoadFrom(dllPath);
pGeo = new CGX_NET("SvMgr", "V1", 2047, null, 0);
The commented-out code runs fine, verifying that paths and DLLs are in the correct places, and load just fine. I left it in this post just to indicate that I've taken those steps.a
The code throws no exceptions, but rather, after bout 5 seconds, the entire c# program exits with the following error return value: 0x80000003.
This is running on a system with Montaj running correctly. The failure happens whether Montaj is active or not.
A Google search for that error code returns a bunch of results about programs trying to display a dialog, and is failing because of that. The behavior (including the 5-second pause) is consistent with an authentication failure, at which point the library might throw up an error dialog. But the Montaj/Seequent login is fine.
Does this ring any bells? Has something changed about authentication? Does this program need to use some other authentication (have I seen a notice about the "Bentley sign-in", in contrast to the legacy Seequent login?).
Any advice would be appreciated.
Thanks,
Bob Cram
Geometrics
Hi Bob, can you please give us some more context?
- What version are you upgrading to and from?
- Are you running in the command line or debugging in VS?
- Are you seeing any error in Windows Event Viewer at the moment the application crashes?
The error seems like an assembly mismatch. The two assemblies you are loading are C#. Is there a reason they are being loaded dynamically instead of referenced as dependencies to the project?
0 -
Thanks for replying. I updated from Montaj 2022 to the current version.
The standalone program is a C# .net UI program.
What's interesting is that it doesn't appear to be a crash - a number of threads exit, then the program exits.
The dynamic references were there simply for testing - dynamically loading provides more granular information about DLL loading. The call that causes the program exit is to code loaded via dependency.
I am looking at questions of assembly mismatch. A decent candidate is that the .net framework or SDK is not in synch with the libraries in the new Montaj install.
0 -
Here is additional UI information from the crash:
[Thread 0] (Current)
pCreate_GEO gxx_geo.cpp (707)
H_AP::sCreate ap.cpp {1232}
H_AP::sSharedCreate ap.cpp {1107}
H_AP::sInternalCreate ap.cpp {452}
H_AP::InitDotNet ap.cpp {452}
AbortCode = A1SW6M8
0 -
This issue was resolved by updating Montaj to version 2025.2.
It is also a requirement that the standalone C# program be built to .NET 8.0.
1
