Default Imagery and Image Type
Is it possible to set the default imagery and image type whenever I choose a new drill hole?
It always defaults to some Downhole imagery that no one looks at, and it take a little mouse movement and three clicks to see the intended imagery and image type.
Best Answer
  • JennyNi1
    JennyNi1 Posts: 2 Diamond Rank Badge
    Answer ✓
    Yes, under Data Definitions > Imagery Types and then select the imagery type you want to configure, if you check the 'Display' checkbox under Definitions for the one you want by default that will be what loads when you click to view the collection.
