GeoStudio API (Python)
Hi everyone,
I’m automating SLOPE/W runs via the GeoStudio Python API and I need to access the reinforcements so I can read and modify, line-by-line, the Tensile Capacity and Pullout Resistance.I’m struggling to find the correct object tree/collection for reinforcements in the API.
What I want to do
- Iterate over the reinforcements defined in the model (either Line or Face mode),
- Read/modify
TensileCapacityandPulloutResistancefor each element, - Solve the analysis and store the critical FoS, looping for combinations (sensitivity/reliability workflows).
Environment
- GeoStudio: 2025.1 (SLOPE/W)
- Python API: gsi-2025.1.0 (official wheel)
- OS: Windows 11 • Python 3.12 •
grpcioup to date - Project: .gsz file with reinforcements already defined in the GUI
What I’ve tried / what I can see
- I can open the project, select the analysis, and list
CurrentAnalysis.GeometryItems(e.g.,Regions,Boundaries, etc.). - But I cannot find where the reinforcements live.
- === Scanning likely collections ===CurrentAnalysis.GeometryItems.Regions: 9 items=== Trying direct collections ===(no obvious 'Reinforcement', 'Nail', or 'Tieback' collection shows up)
- I also looked under
Project.Library(materials/structures) but didn’t locate reinforcements there either.
Concrete questions
- What is the correct path/collection in the API to access SLOPE/W reinforcements? (Something like
analysis.Reinforcements,analysis.StructuralElements,Project.Library.ReinforcementTypes, …?) - How can I iterate by “line” (Line mode) or by face (Face mode) and, for each item, read/write
TensileCapacityandPulloutResistance? - Are there API differences between Face-defined vs Line-defined reinforcement that I should handle (e.g., property inheritance by material/layer)?
- Is there any official example (or code excerpt) that demonstrates reading/writing these two parameters specifically?
- If reinforcements aren’t under
GeometryItems, do they live under a Structural/Support elements node or in Libraries/Templates referenced by the analysis?
I can attach a minimal .gsz with 2–3 reinforcements if that helps.
Thanks!
Such a great question, Lucas! 🙌
I’m tagging @IngridAraujo @JayfanChou @ShishirKumarSikderAm @DivyanshRaunak since you might have run into this before. Would love to hear if you’ve figured out where reinforcements “live” in the API and how you go about editing them.
Feels like a lot of us could benefit from knowing how line vs face mode works.. so thanks for bringing it up! 👏
0 -
Hi Lucas,
We are in the process of creating better documentation, more YouTube videos, and example scripts. Some example scripts have been added to the Seequent Learning Management System (Resources). In our next video, we hope to highlight how dynamic sketch text (Sketch - Text - Insert) can be used to find the object of interest. Here is an example of some code that will hopefully help you resolve the problem:
Note: 'object' is unused but was retrieved so that I could see the data structure representing the Pullout Resistance and therefore discern to update 'Value'.
2 -
Hi @KurtisMiller, understood that the API documentation is still under preparation, but any chance that I find a list of the target object names?
(i.e. "CurrentAnalysis.Objects.ReinforcementLines[1].Reinforcement.PulloutResistance")
I would like to access other properties of the reinforcement such as length and orientation etc. Many thanks!0 -
Hi @KurtisMiller , while will you are waiting for our documentation/videos, can you try the following steps to identify the 'OC' … object controller.
- Open a GeoStudio project file that comprises Reinforcement.
- Sketch → Text → Insert Field → find your object and insert the text.
- Copy and paste the OC into your python script.
3
