How can i generate dipole dipole/other reciprocal arrays using ABEM terrameter protocol tool ?
In resistivity surveys, a reciprocal measurement involves swapping the positions of the current electrodes (A and B) with the potential electrodes (M and N) and taking the measurement again.If the instrument and setup are working perfectly, both measurements should give the same apparent resistivity value (within acceptable error). The difference helps you check data quality.
I have recently watched Harry Higgs' instructional videos on YouTube (https://youtu.be/ze5DuaFCKOU?si=nRgzOQy-cCPqSeVH) regarding methods to avoid problems during data acquisition . In those videos, he highlighted three key approaches to maintaining high-quality data, one of which involves the use of reciprocal arrays. While I am familiar with using the ABEM Protocol Tool, I am unsure how to create a reciprocal array. I would greatly appreciate any guidance or assistance on this matter.
Best Answer
The issue is solved.
1
