Residual-Regional Separation (FTG)
Hi all, a new learner here. I am working on FTG data on Oasis montaj and still familiarizing myself with the geophysics workflow. I want to separate the residual-regional anomalies of the FTG data. This can be done by wavelength filtering, right? However, I am confused on how to decide the cut-off wavelength for filtering. I read somewhere that the wavelength ranges can be determined using Spectral Analysis. How do I do this on Oasis montaj?
  • FarzanehFarahani1
    FarzanehFarahani1 Posts: 19 mod
    edited July 23
    Hi SyifaSukri,
    You can use the 2D Filtering > MAGMAP Filtering options to apply the wavelength filters you require. You would need the Oasis montaj Processing bundle to have access.
    Regards,
    Farzaneh Farahani,
    Project Geophysicist
  • SyifaSukri
    SyifaSukri Posts: 5
    Hi FarzanehFarahani,
    Thank you for your response. I am looking into it. Much appreciated!
