Central connector
Options
Hi,
How do you assign connectors in leapfrog central for users.
  • NiklasSääv
    NiklasSääv Posts: 18 mod
    You use the Central portal (https://central.seequent.com/login), under the Users tab. Each user has a tickbox on the left side.
    You have to be assigned as an admin on that Central instance in order to see this.
    The only way is forward!
