Creating a classic strike-dip symbol in Plan View Layout
Hi everyone, I am making some plan view layouts with structural data (basically making a map) but I cannot find a way to add the classical strike and dip symbols. I have the structural data plotted, but only as single lines with no indication of the dip direction. Is there a way to do this? Many thanks
  • PrachiChitkara
    PrachiChitkara Posts: 393 admin
    edited May 14
    @ChitraliSarkar or @PhamVietThai tagging you here in case you've explored something similar in your workflows.
    And if anyone else in the community has tips or suggestions, feel free to chime in! 😊
  • PhamVietThai
    PhamVietThai Posts: 6 Fluorite Rank Badge
    edited May 15
    Emily,
    I am currently using a temporary method to replace the hatch patterns with color. I’ve used the "Render Image" feature to generate an image and imported it into the Plane View. This allows the area to be visualized using color instead of hatch lines. I hope this is helpful. At the moment, applying hatching directly in Leapfrog is not possible.
    I'm not sure if the dip and dip direction you're looking for are actually shown in the Plane View.
    or
  • EmilyHinshaw
    EmilyHinshaw Posts: 4 Corundum Rank Badge
    @PhamVietThai Thanks for your reply! I'm not sure if the hatching approach is useful to me. But how did you add those blue and pink symbols along your fault trace?
