Thickness of Non-Leapfrog Volumes
DanielMacIsaac
in Leapfrog
I was given a closed mesh not made in Leapfrog and I would like to make a grade x thickness evaluation of. Is it possible to do a thickness evaluation of such a volume?
I was hoping to follow this work flow: https://www.seequent.com/grade-thickness-contouring-in-leapfrog-geo/
Hi,
Yes, you can create a thickness grid and evaluate it onto an imported mesh. I found this workflow which will take you through how to do it.
Once you have this evaluated onto your volume, you should be able to follow the workflow in the video tutorial you posted above.
2 -
Thanks Annabel!
