Grouping Faults
Options
Hi All, is there a way I can group faults by category (extension vs. thrusts etc.)? To avoid loading them all individually
thanks.
  • ClareBaxter
    ClareBaxter Posts: 4 mod
    Hi Paula, if you have your faults under meshes you can create sub-folders to add the different category of faults too. Then simply bring in the entire sub folder to bring in all the meshes under it.
    If the faults are in the Fault System of the GM, it is a little trickier as there is not the subfolder option and it is ordered in chronological order. Try setting up a system in the initial part of the name of the fault surfaces and then you can select multiple faults to come in using 'shift' and 'ctrl' window keys. These keys can be used as well in the shape list to change the visualisation of the surfaces.
  • PaulaOgilvie
    PaulaOgilvie Posts: 2
    Thanks Clare!
