Postgresql ODBC connection
Can someone explain me where to find information about editing the ODBC connection to a postgresql database?
Thanks!
  • That's Ok. I figured out how to do it
  • how did you do it?
    i just get
    "An error occurred when reading "collar":
('42P01', '[42P01] ERROR: relation "collar" does not exist;\nError while executing the query (1) (SQLExecDirectW)')"
  • PrachiChitkara
    PrachiChitkara Posts: 426 admin
    hey @ViorelHoroi great to know you were able to figure it out :) Can you share your findings with @RiyanAbraham
  • Hi @RiyanAbraham
    If I understand well your message you figure it out how to connect to the PostgreSQL server (creating an ODBC connecton on your local machine and using that to connect Leapfrog to Postgres).
    For me, the message you obtain is a proof that the connection is working. It's just that, probably, the database on Postgres it's not exactly structured or organised like the Leaqpfrog needs.
    Sorry, I cannot help you more than that.
    In my case, it was just that I did'nt figure out how to configure the ODBC connection.
  • Hi everybody
    I would like to follow on this. I got the same error as @RiyanAbraham :
    We figured out that the views or tables must be listed under the default schema "public". So now it works.
    I hope that helps anybody in future.
