Data migration to central
Options
Hi, we have a static leapfrog project (not on central) with flagged tables and ore domains (90) created in a geology model using new vein system.
We are currently migrating to central but at the same time changing grids. What is the best way to copy interval flagging from one project to another using central?
Thanks
  • NicoleCasilla1
    NicoleCasilla1 Posts: 5 mod
    Hi Tim,
    You can export the interval flagging in Leapfrog by:
    It saves it as a text file (locally) which you can import to another project. There's explanation on the help page regarding the different import options, Importing Interval Selection Edits. Unfortunately, it wont' be a direct Central driven process, however, you can upload the .txt files in the data room to keep a record of the Import/Export.
    Hope that helps.
    Cheers,
    Nicole
