Leapfrog Geo Interval Selection Bug
Options
In Leapfrog Geo, there's a repeatable bug where if the Interval Selection editor is forced to close by starting another editor and it also needs to save changes, then the visible Categories/Lithologies will be reverted (undesirably) to previously visible Categories/Lithologies. Here are the steps that I can recreate this bug:
1.Start the Interval Selection editor.
2.Change the visible Categories/Lithologies (in my instance from Category M18 to M20)
3.Select and assign an interval from one Category/Lithology to another without saving.
4.Perform a task that forces the Interval Selection editor to close (in my instance, Editing points in the hanging wall of an existing Vein object).
5.Click the Close Other Editor in the Dialog Box "An object is already open".
6.Click Save in the Dialog box "Save changed to "object" before closing?".
7.When the hanging wall editor appears after saving changes, the visible Category will revert to M18, even though M20 was the only visible Category.
If I save and close the Interval Selection editor manually before starting another editor, then the visible Category remains on M20 and does not revert to M18 - which is the desired effect.
  • NicoleCasilla1
    NicoleCasilla1 Posts: 5 mod
    Hi Christian, thanks for flagging this bug through. Are you able to pass this on as a support ticket by emailing support@seequent.com with what you've outlined above? We're interested to see what's causing this bug and if we can fix this in the new release. Looking forward to you email.
    Regards,
    Nicole
