Coincident Faults error on Fault System
Options
Hi,
When I whant to apply a "Fault System" I get a "Coincident Faults" error as shown on the image.
The fault as the same boundary coordinates as the GM.
Any idea what could cause the problem?
Thanks you!
  • CarlyThorpe1
    CarlyThorpe1 Posts: 19 mod
    Hi @PatriceLaliberte2 It looks like the fault that you are trying to add is the same or a very similar surface to the topography in your project which is used as a boundary for the geological model by default. If you would like the model to extend above the current topography you can simply deactivate the use topography option in the boundary settings for the geological model.
    Thanks
    Carly
  • Sorry for the late reply and thanks Carly for tip. It did work.
