How to define initial value of Y-axis on long section
DevinAToddRoth
in Leapfrog
I'm trying to create a long section with a y-axis ranging between -400 up to 200.
How can I set these values directly? the suggested initial values seem arbitrary and can be adjusted but only by a few units, and there is no way to get it to a round value (ie -400, -450, etc).
It looks like the defaults that are set when you create the long section might not be what you wanted. You can edit the top and bottom of the long section from the project tree rather than in the layout. Then you will be able to adjust it further in the layouts.
Thanks
Carly
