Can I filter collars by data present in interval columns?
Options
AnnaBest
AnnaBest Posts: 1
I have a lithology interval table that has columns with data present or absent sporadically. Can I filter the collars based on whether there is data present in the attached interval table or a specified column in the table? I couldn't figure out how in the calculations tab.
This would be useful for e.g., only showing lithology if there have been picks made in a column, or only showing collar labels if samples exist at a location.
  • CarlyThorpe1
    CarlyThorpe1 Posts: 19 mod
    Hi Anna,
    This is a tricky one, since calculations work on a row-by-row basis not per hole. If you can import a 'partly logged' flag from your database onto the collar table that is the best option. Failing that the best workaround I have found in Leapfrog is to create a new category selection on the collar table then flag the holes as partially vs fully logged. It's not automatic but still dynamic as you can add more holes as you get additional data
