15 million rows .csv file of geophysical points data
CarlosBravo
CarlosBravo Posts: 5 Fluorite Rank Badge
edited May 2024 in Leapfrog
Hi! I have a .csv file of geophysical points data (x,y,z, resistivity), each file has 15 million rows. I was trying to make a numerical model but it takes a long time. What other option would help me to process this information in a more efficient way.
PS1: my computer has 128 gb RAM memory.
PS2: Before the information was only one file of 75 million rows, which was subdivided into three files, and information was filtered until it reached 15 million rows.
  • I need to make the model in Leapfrog geo
  • Did you try importing your data as points in leapfrog?
  • hello! if the data is loaded that way. When processing it, how to generate a numerical model, it takes approximately 3-5 days.
  • SuzanneVhieTenorio
    edited July 2024
    would you mind to share the data? Ill try loading.
  • Por lo que entiendo necesitas hacer un modelo numérico con tu información de puntos. Puedo apoyarte necesitas mandarme mensaje a mi correo electrónico, solo tendrías que compartirme tu información para procesar los datos y mandarte el producto
