Geostudio V.S. ABAQUS Results Comparation in CK0DC Condition
Options
Dear all,
I'm using the ABAQUS 6.14-4 and Geostudio 2022.1 to simulate the CK0DC test (Drained triaxial compression test on K0 consolidated clay), the soil material model is MCC (Modified Cam-clay), and the model parameters keep the same in two applications. The main purpose is to see if it's the same as the stress-strain path (i.e. q-εa curve, where εa is the axial strain, q is the deviatoric stress) in different OCR (Over-consolidation ratio) conditions. However, I found that the results given by these two software are very different, I DON'T know where the key point is. Is there anyone who could help me? I'd appreciate it. Warm Regards, Chou.
Attached are the detailed model files of ABAQUS AND Geostudio.
  • IgnacioEscudero
    IgnacioEscudero Posts: 11 mod
    Hey!
    Thank you so much for getting in contact with us
    Generally speaking, the difference in results is likely due to a wrong boundary condition in either GeoStudio or ABAQUS. Our external examples "Triaxial tests on Modified Cam Clay soil" and "Parameterizing the Modified Cam Clay Model", which simulate a consolidated drained condition, might be helpful as a sample project to verify their model setup.
    We will look up the files in order to get a deeper answer
    We'll get in touch!
