Irregularities During Multiple Map Export
Options
I'm encountering a couple of issues when trying to export multiple maps from a project.
I have generated a series of maps as A3 landscape figures. When I export them individually as a PDF they export at the correct size, when I try and export multiple maps as PDFs they all present an error stating:
"The dimensions of this page are out-of-range. Page content might be truncated." - The PDF then just shows a blank white square.
Similarly, it appears that when you export a map as a JPG it completely ignores the size/scale of the original map.
  • William;
    The multiple map export to pdf that you mention is a known issue and it is being fixed for the next release. In the meantime, although not ideal, you could create a script to automate multiple map exports.
    Thank you for mentioning the JPG size issue, we will investigate.
