Leapfrog Geo: Is there a way to export specific/filtered drillhole intercepts to DXF?
RaneeJoshi1
in Leapfrog
I know that there is a workaround to export traces via Exporting and Importing OMFs but that does not work when I just want to export certain intercepts (e.g drillholes with assay grades greater than a cutoff )
Thanks in advance!
There is a long workaround. If you create a query filter for your drillholes and export them using the query filter. You can then re-import them as a new drillhole file and output the OMF file based on the new drillhole file you just created.
I believe that there is some development work currently being done on the exporting of traces feature. Hopefully, this may be available in a major release sometime later this year. Cheers.0
