Points projection to the same plane
What is the best way to keep distance between specific points in a projection that are on the same surface or plane
  • NicoleCasilla1
    NicoleCasilla1 Posts: 5 mod
    Hi! You can project your points to any surface by Right-click on the points> set elevation> select the surface to drape the points onto> Ok.
    Hope that works!
