Empty pinch out in vein model
ChitraliSarkar
in Leapfrog
I have copied a vein model and changed the litho code. The new boundary has been created assuming it would automatically generate the vein to the new area. But it is not happening and I notice that the pinch outs is empty and seems to be generating vein some place else.
Hi Chitra, are you experiencing something similar to the photo below where a vein surface is generated where there is no drillhole or points? It has something to do with the vein thinning out and artificially creating a volume when pinch-outs are turned on.
If that's not the case, it would be best to contact support@seequent.com and someone should be able to assist you.
