Cut a block model from a pit shell
fodea
fodea Posts: 1 Diamond Rank Badge
I have a mesh of an open pit mine and a block model of an orebody that projects vertically outside of the pit mesh. Does anyone know how to cut the block model from the pit shell so that I get an accurate calculation of volume/grade for that particular shape?
  • CarrieNicholls
    CarrieNicholls Posts: 4 mod
    Hi there, you can code your block model for the pit mesh using the Grouped mesh functionality.
    Go to Combined Models>New Grouped Mesh.
    Add the pit and then evaluate that object onto the Block Model. You can add multiple meshes as the name implies!
    You can then create a Report on the Block Model.
    Have you tried that?
    Carrie
