Intrusion modeling
CHARLESGLEVERCISSE
in Leapfrog
Hello,
When modeling my intrusion i got a big issue, let's take a section line where i modeled the intrusion, so the intrusion show two volumes because 2 holes do not show continuity of the intrusion but i want to force so that the 2 volumes will be connected.
I'm guessing the intrusion is pink colored?
the easiest way is to use a polyline. you could also use a point (and try give it a disk to control the trend, I see that you've applied some ellipsoid). try different combination: line with ribbon+point with disk, only using point with disk, only using polyline, and so on.
if it doesn't work, I usually play with different mesh resolution.
cheers,
FN
0 -
Many thanks, I will try it
