How to create a geological model from a complex geology map with intrusives and sediments
OscarGuerra
in Leapfrog
Hello I am trying to build a geological model from a geology map. I have the meshes created for intrusives (two intrusions ages Cretaceous and Paleogene), volcanic flows (Neogene), Jurassic limestones and alluvial quaternary. My problem is to create the contact surfaces for the intrusives. I google for tutorials in this matter but no luck. If someone has some hints on this or a tutorial, I will appreciate it very much.
Might you repeat the steps used in creating the intrusive meshes to create intrusive contacts in a model? If you used a polyline to build the mesh, you can "share" and use that same polyline to build the surface.
0 -
Thank you, Gabriel0
Hi @OscarGuerra, We have a build a model from a map on our Seequent Learning page that may be helpful - https://lms.seequentlearning.com/enrollments/160179589/details
For the Intrusion tool, you may need additional polylines, points or structural discs to help create the intrusion better at depth.
We also have a learning course on using polylines, you may find helpful - https://lms.seequentlearning.com/catalog/courses/30375490
