Thrurst/reverse faults in Geo...
HectorMendivil1
Posts: 4 mod
in Leapfrog
Faults tool in Geo is a great one, but trying to model a reverse fault is alwas a time-consuming task; on the other hand, most of the times (depending on data and drilling angles and distribution) normal faults causes the limits of solids between fault block them look as reverse faults. Is there a plan in future releases to control normal and reverse faults solids behavour when cut by faults?
Something like;
1
the same problem here
